Intermittent powering on, not properly detecting batteries
Hi, I own this MacBook A1278, the 2.4 GHz variant. The logic board number is 820-2327-A
Now to the problem. It won’t detect any batteries. The level indicator doesn’t show anything. Charger connector turns amber after plugging in the battery. Also, when testing with ASD EFI, the battery passes every test except temperature reading, which is too high, over the limit. ASD OS can’t even read that sensor. In system profiler, the battery doesn’t show up at all.
In ASD OS the log reads following:
[01/01/01 00:40:06] Temp (TB3T) - Battery temperature (test #1) - Sensor Reads Within Operating Range - Check to ensure that sensor reads within operating range. [00:40:06] ERROR -- 1 [Unable to read sensor] -- (-1.00) TEST FAILED
Another problem with this machine is, that when I push the power button, the screen powers on, as does the hard drive, but nothing happens. After maybe 10-15, depending on the environment, the mac gets warm, and then powers on just fine. When I reboot it, or just briefly unplug the power cable, it turns on straight away. When I let it cool down a bit, it take some time again for the mac to heat up and turn on. When I tried powering the mac on with SMC bypass, the fan ramped up to max RPM as it should, but it never turned on.
PPBUS_G3H reads 12.35V instead of 12.6V, even when the machine is on. I also didn’t find any shorts on this line.
Esta é uma boa pergunta?
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Adicionar imagens a uma pergunta já existente
To deal with the thermal aspect you need a good thermal monitoring app like TG Pro, Again take a snapshot of the applications main window making sure to capture all of the sensors (some may slide below the windows space). Lets see what it tells us as well.
por Dan
It definitely sounds like your battery sensors are fried or damaged in some way. The battery is probably not the cause, which is why it still charges and powers on, but the macbook isn't able to properly manage or read anything about the battery if the sensors are damaged, which can cause the weird boot issues and it not showing up in system information.
por Jordan Fischer
@jfischthecat - Gaining the data first is always a better approach than throwing spaghetti at the wall to see if it sticks, just saying.
por Dan
