Ir para o conteúdo principal
Repair guides and information for portable, battery powered Bluetooth speakers
71 Perguntas Visualizar todos
Ion Bluetooth speaker won't stay charged even after 8 hrs
Ion Bluetooth speaker from Walmart won't stay charged even after 8 hours of charging with no use , unplug for a minute and it dies. Will work while plugged in but that's it.
Esta é uma boa pergunta?
Pontuação 1
3 comentários
I Have A Ion Bluetooth Speaker From Costco
When I Charge My Speaker It Stays Charge
I Don't Have Too Charge For Weeks.
I Play My Speaker Everyday And Can Charge My Phone
Conga Master
por
My Bluetooth speaker will work plug in the wall but I unplug it will not work has to be plugged in all time
por
@detrickmarshall
What is the make and model number of the speaker?
por
Adicionar um comentário
2 respostas
Solução escolhida
Hi,
Given it works when plugged in but not on the battery only, it appears as though the battery is faulty or has failed and needs to be replaced.
I cannot find a teardown video online that shows how to open the speaker, but here’s a link that may help in finding the correct replacement battery.
According to the link, if you have had the speaker for <90 days from new, then the battery is covered by the manufacturer’s warranty.
Esta resposta foi útil?
Pontuação 2
1 comentário:
Thank you, I just came across it myself, just before checking here. Again thank you
por
I have to replace my battery. Want to know if the Ion Bluetooth speaker charging system works with lead acid batteries & lithium.
Pontuação 0
2 comentários:
Mine powers on but won’t connect to Bluetooth only radio any suggestions besides replacing the battery which I did but the company sent me the wrong size
por
you need to download the app and connect to bluetooth thru the app. THEN connect to audio via phone bluetooth
por
Adicionar a sua resposta
Chris Marques será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 87
Últimos 30 dias: 346
Duração total: 6,372
