Ir para o conteúdo principal
Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
432 Perguntas Visualizar todos
Power supply works when logic board is disconnected.
iMac is dead.
I tested the power supply separately from the logic board and all the pins match the expected amounts. When I attach it to the logic board, all the pins are dead, zero volts everywhere.
Q: Does this mean there’s a short on the logic board? Wouldn’t the pins still show a voltage since the short is drawing power?
Q: Do I need to supply voltage to the board to find the short?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Yes, you have a short within the logic board, often it’s the MXM GPU board that fails.
Time to pullout the DVM and check the power rails for a short (without the power supply connected). You’ll need the board-views and schematics for the system.
Esta resposta foi útil?
Pontuação 0
3 comentários:
DVM? Digital voltmeter, right? (Just checking) ;)
por
Also, can I assume that the power supply is prob OK?
por
@Paul Spinelli - Likely, you really need to test the logic board power rails for a short
por
Adicionar a sua resposta
Paul Spinelli será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 42
