Ir para o conteúdo principal
Repair documentation for the initial Sony PlayStation 5 DualSense controller. Model number: CFI-ZCT1W FCC ID: AK8CFIZCT1
52 Perguntas Visualizar todos
PS5 Controller displaying orange with white light
Dear All,
Thanks for taking your time to go through this post.
I recently purchased a PS5 controller to use it with my Mac, iPhone, iPad devices. I do not have a PS5 Console. I was wondering how to charge the PS5 controller. I connected the controller via USB-C cable to Mac and I could see that there is orange - white light that is being seen in the controller. However, even after successfully connecting the device with iPhone, the controller is showing the same light. It is not blinking but constant orange-white light as shown below.
This controller is just 3 days old. Is there any issue with the controller or is the normal behaviour. Also please recommend how to charge the controller. Can I user a power bank (6V/2.1A) to charge using USB-A to USB-C cable?
Your valuable inputs will be of great help to me as I am a starter.
Esta pergunta é pertinente?
Pontuação 1
Adicionar um comentário
3 respostas
If this is a new controller, it must be charged for at least 8 hours without touching it. The PS5 controller orange light is normal when your PS5 controller is charging, and since it’s new and needs many hours of constant charging, this issue is normal, so don’t worry.
Esta resposta foi útil?
Pontuação 0
When connected to any apple device, the light will be orange with a single white light on the bottom. This is completely normal, and means it’s working well. Orange is the default color for apple devices, but the light depends on which player you are on the PS5
Pontuação 0
i had the same problem .
you need to press the PS button with the left d-pad button at the same time .
i think the problem has something to do with a controller update .
Pontuação 0
Adicionar a sua resposta
Avinash™ Kumar será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 27
Últimos 30 dias: 134
Duração total: 1,576
