Ir para o conteúdo principal
The Asus X551CA is a 396.2 mm laptop computer with convenient features for everyday use.
ASUS X551CA-SX030H memory RAM upgrade
Hello
Do you know if this particular model has slot to install additional memory?
In specification is information that is possible up to 12GB.
I found some motherboard from Aliexpress, and with the same processor has additional slot but not sure if original Asus was built in
https://it.aliexpress.com/item/328634703...
Thank you for info
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
I am not sure if your motherboard has a slot for you to install RAM. It seems to vary from computer to computer within this family and I cannot seem to get information on this specific computer. The only way we could find out if your computer has a RAM slot is for you to disassemble the computer, take out the motherboard, and take a picture of both sides.
Esta resposta foi útil?
Pontuação 2
2 comentários:
any chane to check out in some service manuals please? I have to buy memory and dont want return and open witbout reason. This is for mother in law so has to be done correct way :)
por
@Piotr Krupicki See my updated answer.
por
Adicionar a sua resposta
Piotr Krupicki será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 67
Ao todo: 406
