Released October 26, 2018. Models A1984, A2105, A2106, A2108. Available as GSM or CDMA / eSIM, nano-SIM or dual-SIM / 64, 128, or 256 GB / Black, White, Blue, Yellow, Coral, or Red. (Pronounced "iPhone 10 R.")
@stressmaster Unfortunately, I only can connect to routers that support 5ghz Wi-Fi. I can't send even a hotspot to any device until I change the hotspot band to 5ghz.
Did you reboot? Also reboot wifi router at same time. Turn off phone than reboot wifi router
por stressmaster
I did. It doesn't work.
por Omar Attia
@Omar Attia can you connect to other 2.4ghz wifi? Also did you tell phone to forget the old wifi?
por stressmaster
por Omar Attia
It is possible the wire that is the 2.4Ghz in the phone came loose. Or the board has a chip or resistor/transistor burn out.
por stressmaster
Exibir mais 3 comentários
