Ir para o conteúdo principal
Lançada em 2010, a Flip Mino HD é uma câmera de bolso com 4 GB e uma hora de capacidade de filmagem.
Replacement for Flip out USB
Hi there, my Flip Mino HD has a damaged ribbon cable for the USB on the camcorder, I can no longer charge it without the usb. If I can fix the ribbon cable how would I do that, If I need to buy the part where can I buy it from? All help would be appreciated.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
You need to find out how many wires are in it than order a roll of flat ribbon cable from Amazon.
https://www.amazon.com/s?k=flat+ribbon+c...
Esta resposta foi útil?
Pontuação 1
9 comentários:
I can’t find the right one and the cable is physically attached to the flip out usb of the camcorder.
por Compartilhar
@TechVid How many wires is in the ribbon?
por Compartilhar
Alao a picture of that connection will help but it's probably just soldered. The wire can be split apart and soldered into place.
por Compartilhar
It is a flat flex cable and I am not sure how to do micro soldering nor do I own a soldering iron
por Compartilhar
Is it true that I can cut the rest of the cable, scratch a little bit of the torn side of the cable until the connectors are showing on both sides of the torn cable and tape them together with both sides touching? Also thanks for not telling me to get a new camcorder, the camcorder is special to me.
por Compartilhar
Exibir mais 4 comentários
Adicionar a sua resposta
TechVid será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 15
Ao todo: 498
