Ir para o conteúdo principal
The Nintendo DSi is the third iteration in the Nintendo DS line, and made its debut in Japan in late 2008.
Indicator blinking orange, no power
I am also having the same problem after i opened mine since blowing didn't work. i have checked all the connections and looked at the connectors on the battery bit (black and red are in) is there any other way to fix this problem?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
If you plug in the charger into the wall and an orange light indicator appears, try a different outlet. If that doesn't work, try using a different charger, but if that doesn't work then I don't know.
Esta resposta foi útil?
Pontuação 1
i am having a simalar problem. my dsi got mountain dew spilledf on it and it wouldnt work any more. So i realized the batery fried and threw it away. Now whenever i plug it in it blinks the orange light. i just ordered a new batery from amazon. that should do it.
Pontuação 0
Adicionar a sua resposta
jamester1991 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 17
Ao todo: 2,107
