Ir para o conteúdo principal
Um videogame de tv fabricado pela Sony Computer Entertainment, também conhecido como PS4. Primeiramente anunciado em 20 de fevereiro de 2013 e lançado em 15 de novembro de 2013.
1697 Perguntas Visualizar todos
Why does it keep saying unrecognised discs
My disc never reads and is now stuck because of it even if I just bought it
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Make sure to check the following things:
  • No major scratches on the discs;
  • The disk actually starts spinning;
    • You should be able to hear it spin when you're close to your console.
  • There are no stuck discs inside
    • To remove a stuck disc, either hold the eject button until it has been removed, or open the HDD cover by sliding it off, and look on the left side of the console. Between the vent holes should be a small screw that allows you to manually eject a disc.
If none of these apply, it is quite likely that the lens is dirty. Buy a lens cleaning disc, or for a higher success rate, open your console and clean the lens with a Qtip and some isopropyl alcohol.
If it still doesn't work, the Blu-ray drive is mostlikely broken and needs replacement.
Good luck!
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Jayden será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 16
