Ir para o conteúdo principal
Tablet da marca Google com tela de 7". O dispositivo precisa apenas de ferramentas de abertura e chaves de fenda para o conserto. Número do modelo: ME370T.
Tablet won't turn on
Whenever I try to turn on the device it just blinks the notification light 3 times. I’ve tried charging it but no luck. Can someone help?
Update (12/03/2021)
Figured it out. For one it was 5 blinks, not 3, and also you just need to charge it longer it seems. I recommend
90 minutes - 2 hours.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
I would recommend you try a different cable and/or wall wort charger that is a 2a rated one. but it is most likely a cable issue. some use 2 paths of power to charge and if one path is damaged you get slow/no charging.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Jack Swallowell será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 20
Ao todo: 348
