What is causing a yellow smudge across the bottom of pictures
Yellow smudge across bottom of screen on my Z712 IS
Esta é uma boa pergunta?
I’d recommend viewing the pictures on a computer to see if the smudge transfers to that as well. If not, it’s most likely just going to be a problem with the viewfinder. You’ll probably be able to find the part pretty easily. If it does show up on a computer, check the internal components behind the lens and make sure that they are clean.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 31
