Ir para o conteúdo principal
AC power adapter for MacBook, MacBook Pro, and MacBook Air. Uses a self-aligning magnetic connector that disconnects safely when tugged. First-generation (2006-2012) MagSafe chargers have a slightly thicker, L-shaped connector. Available in 45 W, 60 W, and 85 W versions.
How to open the magsafe adapter brick?
Hello, i know its a hard work and it will be a lot of cosmetic damage to the brick of the magsafe, but how can i easily split the case of the magsafe, to solder the wires again?, also i'd like to do minimal cosmetic damage to the charger, thank you :)
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
These things were not built to be opened as there are really no serviceable parts. I've used a Dremel type tool with a cutting disk to get into them with minimal damage. I cut along the seams.
Esta resposta foi útil?
Pontuação 4
Adicionar a sua resposta
Dario será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 1,554
