Ir para o conteúdo principal
Repair guides, support, and troubleshooting information for the first 13-inch MacBook Air to feature Apple's ARM-based M1 SoC (with an 8-core CPU and up to an 8-core GPU). Released in November 2020 and identified by model numbers A2338 or EMC 3598.
How to replace the keyboard keys on M1 MacBookAir 2020?
Is it possible to take out 2 keyboard keys and replace them? What is the normal step by step procedure so I don’t break the keys? I saw some videos on YouTube but I don’t trust them. Do I have to take out the middle of the key on the right side, then left side, then the key will be out like this video?
https://www.youtube.com/watch?v=omYY8fly...
I want to switch the physical Z and Y keys on the M1 MacBook Air 2020 keyboard because I have a Czech keyboard and I am using English language. The Y and Z keys are opposite as I want to use a qwerty physical layout but I the macbook came with the qwetz physical layout.
Thank you
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Pergunta mais útil
What I can tell you the video is the process. But getting the key cap to latch back on is a bit tricky! I would recommend you buy spare key caps as I’m sure you’ll snap the clips.
Maybe its worth the effort to find your way to an Apple Store to have them move the keys around for you.
Esta resposta foi útil?
Pontuação 2
2 comentários:
Hey could you Tell me which kind of clips/hinge I need to search for the m1 late 2020 macbook air?
por
@tizia - This is what I have for the Intel models MacBook Pro Late 2019 - 2020 Key Caps So far they is no availability of the KeyCaps for the new M series systems.
por
Adicionar a sua resposta
Stelios Theodorou será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 58
Ao todo: 9,987
