Ir para o conteúdo principal
A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
Can power supply fuse (F12.5A) be replaced wih a 12A fuse?
The F12.5A ceramic fuse for 700 watt ATX power supply is blown, I think it may have been because of an accidental short. I have searched widely and although different sites list the fuse, no one has one and seem to indicate that the fuse is no longer produced. Would a 12A fuse work or is that half amp a deal killer? The load would be MB, 3 HD, 1 optical drive. Video would not be a gaming one.
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
Solução escolhida
Yess O.5 amp lower is acceptable, make sure to test fuse by checking its continuity through a tester meter always before installing it.
Esta resposta foi útil?
Pontuação 1
1 comentário:
hadn't thought about testing the fuse - useful!
por
Pergunta mais útil
Lower is fine but NOT higher.
Pontuação 2
Adicionar a sua resposta
Jim Lindemann será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Ao todo: 396
