PS4 makes a beep and then turns off, fan doesnt spin
Hello, I have a problem with a ps4, basically this was working perfectly until from one moment to the next it turned off, I removed the power supply and found that it did not work, apparently it was damaged, so to verify that it was only the power source connect the ps4 to an external computer power source of 500w, when trying to turn on the console this makes the typical start sound, turns on the blue light, lasts a couple of seconds and shortly after turns off, during the first attempts to turn it on the ps4 fan began to rotate, but now it does not either, any idea of where the failure could be?, the exact model of the ps4 is CUH 1215-A
Esta é uma boa pergunta?
Hello did you get it fixed? Having same issue.
por Junaid Hussain
