Ir para o conteúdo principal
Repair guides and support for cash registers.
54 Perguntas Visualizar todos
G800 SD electronic cash register
Hi how are u hope ur fine, ,may kind assist me with my G-800 SD electronic cash register,, the upper black button that use 3 keys is missing ,the one that is used to control the use of the cash machine I don't know how i missed it ,and the machine is still brand new never 4been used before, may you kindly help me with replacing that button and please assist me with giving me giving me the user manual again I misplaced it. thanks you
Esta é uma boa pergunta?
Pontuação 1
1 comentário:
You can get the manual for this cash register at https://data2.manualslib.com/pdf4/88/872...
por
Adicionar um comentário
1 resposta
https://www.manualslib.com/manual/872656...
here is a search for repair places. you can call and order what you need but there really isn’t much online as these are basically a closed parts system like ATMs are.
https://www.google.com/search?q=nts+cash...
however if you are referring to the keys that unlock it for use than you can also get them from these places but you will need the serial and model numbers off the register. usually these are a stick on the underside of the unit.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Eva Mogale será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 7
Duração total: 206
