Ir para o conteúdo principal
15" laptop manufactured by Dell at the end of 2016. The laptop is very configurable, uses 7th generation processors and has a grey plastic chassis.
13 Perguntas Visualizar todos
HDMI port not being detected
When I connect my laptop to an external monitor through the HDMI port, no signal is detected. I've changed settings and tried everything. Does the HDMI port need to be replaced/fixed? I can't find any information about this HDMI port for replacement. HDMI cable and external monitor has been tried with other laptops and work fine.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
The port probably needs to be re-soldered or replaced. most phone/tablet repair places can also do this.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Walid Jami será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 7
Duração total: 187
