Ir para o conteúdo principal
Repair or modify the Sphero BB-8 droid
7 Perguntas Visualizar todos
Sphero BB-8 with new batteries won’t charge.
I replaced the batteries with new ones, but they still won’t hold a charge. Does anyone have a schematic or have other ideas what might be wrong and how to fix it?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Replacing rechargeable lithium batteries should be a no-brainer as long as the replacement is either the recommended or compatible one. Like all rechargeable batteries, replacements must meet the same specs. Consumer products with manuals describe general operating principles along with guidelines on charging. This includes tell tale indicators. Review the manual for guidelines on what to look for unless you remembered how the indicators let you know of charging conditions . They’re the only clues of what the charging system is doing. If the charging indicator doesn’t turn on, there may be a failure in either the charging circuit, corroded/loose connections or battery.
Rechargeable nickle cadmium, nickel metal hydride and lithium batteries have unique charging circuits to ensure against overcharging.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Matthew será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 37
Duração total: 595
