Ir para o conteúdo principal
Guias de reparo, desmontagem e informações para a resolução de problemas do iPad Apple de 7ª geração, disponível em versões com Wi-Fi e celular com 32 ou 128 GB de armazenamento. Lançado em setembro de 2019. Identificado pelos números de modelo A2197, A2200 ou A2198.
4013, Boot loop and it would not flash
Hi! I had an Ipad 7 bought in Nov 2019. It was doing fine until very recently where it just suddenly shut down, no warning, while in normal use. It got stuck in a boot loop; recovery mode and DFU doesn’t help at all since it would not recover/update when plugged into iTunes. Error log from iTunes update says the device disconnected before the update can be done, and 3uT flashing log shows failure at 19% every time. I brought it to an AASP as a last ditch effort and, sure enough, they can’t do the repair.
Things are pointing towards hardware failure and a fancy paperweight, but what are the odds of saving the device?
Esta é uma boa pergunta?
Pontuação 5
Adicionar um comentário
6 respostas
Solução escolhida
If 3uTools is failing at 19 percent it will more than likely be a faulty NAND. You would need a programmer and microsoldering experience to do the repair. I would get some quotes from repair shops that offer this service.
Esta resposta foi útil?
Pontuação 3
Try a "forced" restart of your iPad, using these instructions:
  • On an iPad with a Home button: Press and hold the top (power) button and the Home button at the same time. When the Apple logo appears, release both buttons.
  • On other iPad models: Press and quickly release the volume up button, press and quickly release the volume down button, then press and hold the top (power) button. Only when the Apple logo appears (it might take 20-40 seconds), release that button (ignore all other screens that might appear).
If the issue persists, it might be a hardware problem.
Pontuação 0
1 comentário:
I went for forced restart before all the other things, and it does nothing but kept the boot loop going.
por
iPad 7 is defective when iPad get really hot long time of period the soldering of nano melt down un-soldering so all it need is to re-soldering that chip easy fix apple should have a recall for this issue problem
Pontuação 0
I agree that it is an NAND problem. An error at 19 -20% when restoring with 3uTools is always NAND. You could send it to an microsoldering repair center.
Pontuação 0
Yeah, I tried using the only free application 3uTools and it was at 18 percent. I hate the Nands on it and it broke in 2022
Pontuação 0
Causa de ese error 4013
Pontuação 0
Adicionar a sua resposta
Nam Hoang será eternamente grato(a).
Visualizações:
Últimas 24 horas: 12
Últimos 7 dias: 46
Últimos 30 dias: 176
Ao todo: 10,646
