Ir para o conteúdo principal
Repair information and guides for the 2015 Retina MacBook Air. Model A1534
External display as main display on boot up
My display is defective (white oval ring on screen) and right now, I just close the lid when booting up so the external display that’s connected (via a USB C dongle) activates and becomes the primary display. I open the lid and use the Macbook keyboard and my Bluetooth mouse to navigate after. If I don’t close the lid after boot up, the ext display won’t activate.
I’m just wondering if this works on a clean install with e.g. a wired USB mouse connected to the dongle (instead of a Bluetooth input device cause that’s not set up yet).
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
The MacBook Pro’s will allow use with a closed lid using a keyboard and mouse, but the power button still needs to be pressed to turn the system on if you’ve powered down. I’m not sure if the MacBooks will work in the same way or not its worth a try just the same.
With the new Bluetooth keyboard with TouchID I was wondering if it can be used with the older MacBook Pro’s Vs the 24” iMac where it was intro’ed. Sadly, I found this: Magic Keyboard with Touch ID for Mac models with Apple silicon - US English so you need a newer M series system to use it. That would have been a great way to get around needing access to the systems power button.
Maybe its worth looking at replacing the display MacBook 12" Retina (Early 2015-2017) Display Assembly
Imagem de Replace a display compatible with the early 2015 to 2017 model A1534 12" Retina MacBook laptop. Includes the 2304 x 1440 pixel 12" LCD screen, aluminum case, 480p Facetime webcam camera.
Produto
$584.99
Esta resposta foi útil?
Pontuação 0
1 comentário:
I’m selling the Macbook and if the buyer decides to use/test it, I just want to make sure that the way I work on it now will work too when a clean install is done on it.
Currently, my Bluetooth mouse is installed and connected to the Macbook so it’s easy for me to navigate using the ext display as the primary one RIGHT AFTER I power on and close the lid.
I don’t have a wired USB mouse to test and can’t clean install just yet (it’s also my daily driver) so I thought whoever has that experience would know if it’ll work.
por
Adicionar a sua resposta
Eric C será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 25
Ao todo: 2,648
