Ir para o conteúdo principal
Repair guides, support, and troubleshooting information for the first 13-inch MacBook Air to feature Apple's Arm-based M1 SoC (with an 8-core CPU and up to an 8-core GPU). Released in November 2020 and identified by model numbers A2337 or EMC 3598.
175 Perguntas Visualizar todos
How to convert DE keyboard to US keyboard?
I am currently located in Germany, which uses a local keyboard layout. As a programmer, I would like to have a US (ANSI) layout (UK (ISO) keyboard would also be ok) for my MacBook Air (late 2020), how can I go about doing it?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
To start with the uppercases between the US and ISO systems are different! As the Return and shift keys are physically different.
So the only way to convert your system is replacing the uppercase assembly which I don’t think is worth the risks as these systems are so new we still can’t get the parts and if you review these guides you’ll see its not easy trying to take the battery out to swap over MacBook Air 13” Retina Display Late 2018 Battery Replacement and moving things over MacBook Air 13” Retina Display Late 2018 Upper Case Replacement I would personally not try moving the battery as remounting it will be difficult without the glue tabs.
  • Top Case & US Keyboard - Space Grey, Apple P/N 661-15386
  • Top Case & US Keyboard - Silver Apple, P/N 661-15387
  • Top Case & US Keyboard - Gold Apple, P/N 661-15388
I really think you want to stick with the skin or stickers or find a US model and sell your german unit.
Imagem de MacBook Air 13” Retina Display Late 2018 Battery
Guia
Nível de dificuldade:
Moderada
30 minutes - 1 hour
Imagem de MacBook Air 13” Retina Display Late 2018 Upper Case
Guia
Moderada
1 - 3 hours
Esta resposta foi útil?
Pontuação 1
2 comentários:
This seems to be a nightmare, would a conversion to UK (ISO) layout be easier? I would be ok with it alternatively.
por
Not any easier! All you're doing is swapping out the part from US to ISO now ISO to another ISO uppercase.
The other option then is swapping out the keycaps but I'll worn you it took me over a dozen keys to get a replacement mounted back. So you'll need to get a couple of sets as I'm sure you'll damage a few in the process!
In the end given the number of keys needing to be altered really doesn't make sense
Apple Key Caps UK There is no US ISO listed and as you can see the availability is thin at this point in time!
por
Pergunta mais útil
The easiest way to do this would be stickers, laebls. or a keyboard cover.
First, go to System Preferences>Keyboard>Input Sources and click the plus symbol at the bottom left. Select your desired language.
Then put the keyboard cover, stickers, or labels on.
You can change the keyboard layout by going to the top right corner by volume, clicking the flag, and choosing the desired keyboard layout.
Pontuação 2
2 comentários:
I wanted to avoid stickers/covers once I want to keep the feel of the keyboard as the original. But thanks for taking the time to answer.
por
you can convert iso to ansi layout just with stickers... they have a different key layout. also ansi has one more key
por
Adicionar a sua resposta
Gabriel Lencioni Lovate será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 16
Últimos 30 dias: 67
Duração total: 5,047
