Ir para o conteúdo principal
Repair guides and support for the 24" iMac with M1 chip, introduced in April 2021. Identified by model A2438.
Is there a fix for the magnetic connector going out?
I have a lab of M1 iMacs that are beginning to exhibit a new problem. The magnetic power connector appears to be failing. One power supply wasn’t working, so one that was working, was swapped to an iMac that wasn’t powering on. This cord did not provide power to the non-working iMac either. When the power supply was then put back with it’s normally assigned iMac that was working, this iMac wouldn’t turn on anymore. The problem seems to follow the power supply. Any suggestions?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
I don't think Apple has done anything that prevents you from mixing power units with different systems.
In any case I think you need to take the system into Apple to let them fix things (your system is still under warranty).
Anything I would suggest would likely void the warranty and might not work.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Chris será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 40
Ao todo: 1,102
