Ir para o conteúdo principal
Repair information for the Fitbit Ionic. A smart watch with GPS tracker and music player on bluetooth. This device has been recalled for safety reasons.
Adhesive to use to reassemble my Fitbit after battery replacement?
I am in the process of replacing the battery in my Fitbit Ionic but I don’t see adhesive listed under the parts or tools list, which is needed (and noted) for proper reassembly. Can someone recommend something similar to what Fitbit uses? I’m not going to use super glue in case I need to replace the screen battery again. Thank you.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
typically you can use something like
Tesa 61395 Tape
or
Polyimide Tape
be sure to read the descriptions on them to see what would work better for you
good luck
Imagem de 108 foot rolls of Polyimide tape. Perfect match with OEM Apple Part# 922-1731 tape. Half-inch (.5") width.
Produto
Polyimide Tape
$9.99
Imagem de Custom cut rolls of Tesa 61395 double-sided tape for repair.
Produto
Tesa 61395 Tape
$5.99
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Robert Simons será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 25
Ao todo: 325
