Ir para o conteúdo principal
Repair and modification information for the Creality CR-10S Pro, a 3D printer from the CR-10 series released in 2019. This first version was succeeded by the CR-10S Pro V2.
Why won't the 3 d filament feed?
Why won’t the filament feed on my Creality CR 10s Pro V2
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
is the feeder motor activating? can you go into settings on the screen and make it feed by advancing it in the settings/refuel/ feed? if it will not feed at with that i would check voltage to the feeder motor and it no voltage that is the issue first. if it continues i would check the main board voltage. i have had the main board go out on one of mine.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Charles Wright será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 18
Ao todo: 385
