Ir para o conteúdo principal
Announced on October 13 and released October 23, Apple's flagship smartphone for 2020 features a 6.1" OLED display, a triple-lens rear camera system with LiDAR, and 5G. Successor to the iPhone 11 Pro.
91 Perguntas Visualizar todos
Display Cable and Digitizer Cable Broken During Disassembling
Please my display cable and digitizer cable both broke from the connector when disassembling my device too much pressure was exerted. I don't want to buy a new Display please does anyone have a fix for this. Image included
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
If those flex cables are damaged or broken, your only option is replacing the screen. If you wanted to try it yourself, you need to move the OEM front sensor assembly to the new screen so you will still have Face ID. Here is a link to MobileDefenders, where you can choose which screen you want to get. They have three different options for the 12 Pro. Also, you will need an iCopy device if you want to have True Tone on the new screen.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
EYITAYO OYEDO será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 142
