Ir para o conteúdo principal
Lançado em 22 de setembro de 2017. Modelo A1863, A1905. Disponível com GSM ou CDMA / 64 ou 256 GB / Dourado, Prateado e Cinza Espacial.
873 Perguntas Visualizar todos
Shaking camera iPhone 8
Hey, I’ve got an iPhone 8 here with a camera that shakes around whenever trying to take a picture. I’m thinking something isn’t secured. Should I just replace the bezel, try to tighten some screws, or replace the whole camera and sensor set up?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
i know this might sound silly but can u take a video of the problem happening? that might help with people understand what is happening exactly.
por
Adicionar um comentário
3 respostas
Pergunta mais útil
This sounds like a parts problem. Replace the camera, there is most likely damage that is causing the focus mechanism to act haywire making the shaking effect.
Esta resposta foi útil?
Pontuação 1
Replace the whole camera. The fault is within the camera, some magnets or coils became detached with the lens frame, causing the OIS feedback to runaway.
Pontuação 1
I believe that they had an issue with the iPhone 6 or 6s try putting a small magnet next to the camera and see if it fixes it if it does it needs a new camera. I would like to see what happens before I can give you a better diagnosis.
Pontuação 0
Adicionar a sua resposta
Thomas Skendzel será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 40
Duração total: 1,024
