Ir para o conteúdo principal
Microfone USB de mesa com saída para fones de ouvido.
USB Plug Out of Place
Hello, the USB joint on my Blue Yeti microphone is out of place. Somehow while the cable was inside, it got bumped around or yanked the wrong way, and now the USB socket is dislodged.
I’ve watched some Youtube videos about how to fix it, but I don’t have any soldering equipment. Do you have any suggestions on how I might fix this?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
unfortunately without any soldering equipment to reseat the joints the only alternative is to send it to someone who does have the capability to fix it. typically its not very expensive to have done.
usually you can get a decent soldering iron from amazon and some solder and flux. it just depends on what you want to do.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Rose Whitcomb será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 51
Ao todo: 1,455
