Very high leak rate on report screen
I get very high leak rates 40 to 70 L/min indicated with no mask seal alert and no warnings. Mask,tank,and tube all check good with no leaks
Esta é uma boa pergunta?
i have same problem i fix it by replacing the mask and program the cpap with the new mask .. it works.
Esta resposta foi útil?
I have the same issue. I’m replacing the first internal gasket before I try the harder to replace air pump gasket. https://www.directhomemedical.com/resmed...
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Ao todo: 730
