Ir para o conteúdo principal
Released November 2020, the PS5 console features vastly upgraded visuals and an innovative new Dualsense controller. The space-age black-and-white color scheme is a noticeable departure from PlayStation designs of the past.
PS5 SSD installation - replacement screw and spacer
I tried to install a new WD SN850 SSD in my PS5 last night. However when I went to remove the screw and spacer in the bay, the screw was stuck, and I just can’t remove it at all. I’m looking for a replacement screw and spacer to fit the SSD. Does anyone have any recommendations from Amazon UK or any other retailer? I’ve contacted Sony, but they haven’t got back to me at all, which isn’t a good sign. Many thanks in advance.
Esta é uma boa pergunta?
Pontuação 5
9 comentários
I got the same problem too. Currently trying to find similar screw and spacer in SEA market but can't find nothing
por
@Akifan Jannata I still haven't had a response from Sony Customer Support. I'd happily buy the screw and spacer if I knew what I was looking for! So frustrating!
por
Hi i have the same probleme if one of you find the good dimension for the screw can you tell me
por
To replace the screw that holds down the M.2 access cover, use a M3 × 16 screw.
To replace the screw that holds down the M.2 SSD drive, use a P3 × 10 screw.
To replace the spacer that supports the M.2 SSD drive, use a spacer with the dimensions φ5.5 x 3.95 mm.
por
Where do they sell the spacers? I can't find it with an internet search.
por
Exibir mais 4 comentários
Adicionar um comentário
5 respostas
Solução escolhida
I have found a screw that has done the job for me. I got the M3-0.5 x 10mm flat head phillips screw, which fits perfectly. I didn't need a spacer either. The screw did the job on it's own. Hope that helps
Esta resposta foi útil?
Pontuação 1
2 comentários:
From which UK shop?
por
I ordered a new screw and spacer on Amazon. So am I good to just leave the stuck/stripped one in it’s original 110 slot?
por
This is the screw I replaced the original stock screw inside the ssd bay that holds down the ssd.
Update (06/05/2022)
This is the original screw that came with the ps5 that I damaged.
Pontuação 0
2 comentários:
4-40 x 1/2 in. machine philips pan head screw fits inside the original ps5 spacer
por
Here are images to see that the 4-40x1/2in. screw fits inside the ps5 ssd bay.
Pontuação 0
3 comentários:
Bro what is the size of screw you displayed in 2nd image
por
Is the screw properly fixed with ssd?? And what's the size of it?? Plz inform me Asap.
por
Sorry for the late reply. The screw size is 4-40x1/2in screws.
por
https://amzn.eu/d/iJrAFeV
Pontuação 0
I found this on Amazon UK, "Amazon's Choice" for ps5 ssd screw and spacer
DevineCustomz® Compatible For PS5 Mounting Solid State Disk SSD Screw Replacement Nut Console Motherboard Metal Screws
Pontuação 0
Adicionar a sua resposta
Kevin McCubbin será eternamente grato(a).
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 59
Últimos 30 dias: 220
Ao todo: 36,752
