Blue tooth function broken! otherwise works great
Blue tooth function broken! otherwise works great.
How can the blue tooth function be repaired?
Esta é uma boa pergunta?
Hi Renee,
I need a little more information before I can answer. But, have you tried resetting the connection between your speaker and the device you’re trying to use? Just like any other Bluetooth device, sometimes the connections needs to be reset. If you haven’t already, try these steps.
Let me know if this works. If not, then we can start troubleshooting a hardware issue.
Esta resposta foi útil?
Thanks, Kris. I have tried all of that and nothing worked. the blue tooth functionality is broken :(
Darn. I was really hoping this would help. When you say broken, do you mean the physical button that activates the Bluetooth itself?
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 197
