Ir para o conteúdo principal
Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
432 Perguntas Visualizar todos
Internal speakers not working despite showing as output device
Dear all,
I would like to make use of the vast knowlegde of this user base, so here it comes! The following problem occured: I received an iMac from work that was being replaced, thus I do not know the status of the iMac, although it was not replaced because broken, just as an update.
I opened the device via removing the screen removing, to clean it form dust and to check if a SDD or HDD was installed. Fortunately an SDD was installed, and not much dust was gathered internally. So I cleaned the vents and the rest carefully with a duster. Afterwards I installed MacOs, which succeeded using internet recovery.
Then the problem starts to occur: only the left speaker was working (I don’t know if the right one was already broken), and a few days later the left one stopped working. Also the microphone seems to be broken.
In MIDI setup everything seems normal, I tried every setting. In sound board in settings the internal speakers are showing and volume can be changed as if nothing was wrong. Furthermore, sound works with external headphones plugged in, or using airplay. So the DAC should be working, and probably the audio card too. Maybe the amplifier for the internal speakers, or the internal speakers are broken?
I tried:
resetting PRAM, SMC, doing the apple hardware diagnostics short and extensive, killing AirplayXPCHelper, killing coreaudiod and checking the cables from logic board to speakers, which i disconnected and reconnected. Now I am stuck.
Does anyone have an idea? E.g. how to test if the speakers are functioning, or how to test if the audiocard is functioning? Or where on the logic board is the audio card connected? Every info is helpful!
Thanks in advance,
Remi
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Open up your Preferences > Sound control panel and click on your Speakers. Check the balance control is in the middle position. Did that fix things?
If not, plug in a headphone into the jack in the back, do you hear out of both headphones? If you do unplug the headphones, did your speakers start working?
Often the headphone jack gets messed up either with a bad plug or dirt. Within the jack there’s two switches which send the signal to your speakers as you can see here
It’s possible the cable was not properly seated if you took the logic board out or the socket is bad and needs replacement iMac Intel 21.5" EMC 2428 Audio Ports
Review this guide iMac Intel 21.5" EMC 2428 Logic Board Replacement jump down to Step 32.
Imagem de iMac Intel 21.5" EMC 2428 Audio Ports
Produto
$19.99
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Remi será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 50
