Ir para o conteúdo principal
Lightweight fleece jackets maximize core warmth without weighting you down. They wick away moisture and dry quickly to handle the most grueling of outdoor pursuits.
How to repair pocket, seam split so contents fall through
I have a many, many years old Patagonia fleece jacket and one of the hand pocket seams blew out years ago- I wear it, reminding myself not to put anything in pocket, lest it be lost to the ground. Would like to finally mend this and would appreciate suggestions.
Thanks - Rebecca
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hi Rebecca, We have designed and constructed many fleece garments over the years with different pocket constructions, this could be as easily as applying a straight stitch, onto the existing seam that has opened on the pocket bag with matching colored thread. However in order to provide best recommendation could you take a picture of the area in question? Take a picture of the inside and outside view of the jacket where the pocket is located, please indicate exact area where seam has opened in the picture with your finger or a pencil?
You could also send it into us for repair if you like at Patagonia. https://www.patagonia.com/repairs/
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Rebecca Moore será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 3
Ao todo: 321
