Ir para o conteúdo principal
The third generation Pixel released by Google in October 2018.
104 Perguntas Visualizar todos
My phone is constantly overheationg, how can I fix that?
Ever since replacing my Pixel 3’s battery my phone is overheating constantly, I’m guessing this is because in order to replace the battery I had to remove part of the thermal sticker that connected the battery to the main board (As seen in Step 13 of the battery replacement). When I did this step I wasn’t able to remove the sticker from the battery and just ended up tearing the sticker off the battery.
What can I do to fix this? What can I add in the phone to help my phone’s thermals now that that this thermal sticker is damaged?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Have you had any luck finding the thermal tape for the battery? I have the same issue and have held off reassembling my phone for the time being. It's possible there won't be an issue with overheating but if there is I would rather not find out after sealing it all back up.
por
Adicionar um comentário
1 resposta
Solução escolhida
you might be able to use a .05 or thinner thermal pad?
or try this stuff maybe. https://www.amazon.com/J-V-Converting-AF...
Esta resposta foi útil?
Pontuação 1
1 comentário:
That was what I ended up doing, and it didn't fix it perfectly, but it definitely improved the problem!
por
Adicionar a sua resposta
David será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 7
Duração total: 47
