Samsung Galaxy S9 motherboard swap
I have purchased a fully working Samsung Galaxy S9 and will be swapping the motherboard from the old phone to new phone. ( will be cleaning the original motherboard from water damaged phone using some 99.9 isopropyl alcohol prior to swap and hope for the best, I believe the motherboard is OK and just the screen on the original phone was damaged.)
What I need to know now is on the new phone prior to swap, do i need to go through setting up the new phone prior to motherboard swap or do I swap before doing phone setup or does it not make any difference either way?
Thanks
Esta é uma boa pergunta?
Thanks everyone. the motherboard swap worked.
So a Galaxy S9 motherboard survived a full wash cycle in a washing machine just damage to touch screen only.
Purchased a mint condition S9 off ebay for £134 and having cleaned the original motherboard from water damaged S9 with 99.9% Isopropyl alcohol and swapped it over to new replacement phone and powered up the phone everything works!!!
Thanks for all the advice.
por diezeltruck
Good job! Happy it worked
por Innovatrix Repairs
