Ir para o conteúdo principal
one work, one doesn't
hi i have a iPod Nano that was washed and i have another one that just does not want to hook to iTunes. The one that was washed, wants to connect to iTunes, the screen just does not work. Can you replace the pin connector in the one that has the screen that works?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
william, only if you know how to solder very small and intricate pieces, I think there is something like 30 points to need to be de-soldered and then re-soldered with the replacement. All this without shortcircuiting the connections. So, possible ? Yes, depends on your abilities.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
william será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 297
