Laptop Wont Turn On
Hi Community,
All of a sudden my laptop wont turn on, wont charger etc. just nothing. Is there any diagnostics that I can do myself without sending to apple store or local guy? It seems as though it's the battery, no keyboard lit up, nothing.
I have a multi-meter fyi and I have the fixit screwdriver kit. Can I test the battery taking off the back cover?
Thanks!
Al
Esta é uma boa pergunta?
7 comentários
Will the laptop turn on if you disconnect the battery and plug in the charger?
por Andrew S
Thank you Andrew. Connected without battery and just cable. It went on but now 500% kernel task makes the computer unusable. Your thoughts?
por Albert Cav
Hey Andrew, cant start it in Command R mode either. What the fudge happened to my laptop?
I'm going to try to copy files over to external HD in 500% kernel task mode even if it takes a long time right now.
por Albert Cav
@albertcav Sounds good. If you run into that problem in the future, you can try Option+Command+R or Option+Shift+Command+R instead(The process is different for Apple Silicon devices).
por Andrew S
Are you saying this machine is done? Once I get my files etc from HD. How do I fix this machine if I do at all?
por Albert Cav
Exibir mais 2 comentários
