Ir para o conteúdo principal
Guias de reparo, manuais e ajuda na resolução de problemas para iPhone 11. Aqui você recebe tudo o que precisa para consertar por conta própria o seu iPhone 11.
LCD?/Screen is Unresponsive To Touch
Dropped my IPhone 11 on hard ground, only one crack went to screen. However after 2 days, the screen became partially unresponsive (the bottom bit didn’t respond to touch). Now 4 days later, screen is totally unresponsive to touch ; Siri works with Hey Siri, phone unlocks with Face ID, side buttons works, camera works, but the screen. responds to no physical touch. What should I do?
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
sounds like your device needs a screen replacement, you can either take your device to a mobile phone repair shop to get it replaced for a fee, or you can use this guide to learn how to replace the screen yourself, if you are not comfortable opening your device then I recommend having a repair shop replace it for you, you can read the guide on replacing your phone screen here: Substituição do painel da tela do iPhone 11
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Jup K será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 41
Ao todo: 552
