Fixing the backlight and Testing the backlight
there is no light but the LCD works using a flashlight i can see the LCD i like to know the volts that the backlight needs so i can test the light and is there a way to do this then i can find out if it is the inverter or the cables
there should be a way to feed the backlight with external power
thank you
Esta é uma boa pergunta?
