Ir para o conteúdo principal
The Kindle Fire, Fire, or Amazon Fire is an Android-based media tablet by Amazon with a multi-touch color display. Repair requires only screwdrivers and prying tools.
Kindle Fire battery maker?
Hi,
Thanks for the teardown article that was really helpful. Just out of curiosity, do you guys know who made the battery? Possibly Samsung SDI or LG Chem?
Thanks!
Update
Thanks for the answer. I just realized that the tear-down photo actually had a company name on the battery right in front of the product number - ATL (Amperex Technology Limited). I wonder if they used their own cell or only did the packaging.
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Pergunta mais útil
It's very strange, all the model number searches return no results, must be a very custom job. It's possible if iFixit looked under the label or otherwise (safely) took it apart they could find further markings.
I had some Chinese friends look at the characters, and it's the exact same as the English, so no hidden numbers or signatures there.
I'd say not Samsung since it's Chinese, and by the same logic not LG (neither has manufacturing centers in China), so I'd look at Foxconn (known to manufacture kindle parts, manufactures most computer parts in the world) or maybe Quanta (Taiwanese company known to have worked with previous kindles, has a lot of Amazon/RIM overlap dating back to the original kindle, in light of the similar hardware between playbook and this, I think it's likely [speaking of which, iFixit should teardown a playbook, would be an interesting comparison]). It's worth noting the labels all say "China" not necessarily PRC or ROC, so we can't rule out Taiwan.
edit: looks like there is a playbook teardown, I'll try examining the two images.
edit2: Ok, primary analysis says they look suspiciously similar, as in, same manufacturers, (it was done by Quanta), warnings and symbols are identical and verbatim, the model numbers and barcodes look very similar too, the only difference is the capacitance.
edit3: I'm gonna go ahead and call it for Quanta
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Ron Suh será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 22
Ao todo: 3,477
