Is there a dual sim support for i11 Pro Max?
Is there any other brand that does it? or it just not really compatible for this? I’ve seen the i11 have it, but its for the China/Hongkong model.
Esta é uma boa pergunta?
hello Anthony,
every iPhone from the xs model supports eSim (the first physical, the second electronic - given by the service operator). DualSim means - two sim cards in one tray - an old Samsung solution, rarely found today.
Esta resposta foi útil?
Yes - iPhone 11 Pro Max does have a dual sim support. Apple ''released the support for dual-sim'' on iPhone XS and newer. However, the dual sim support is not actually what you're thinking of.
Dual-sim support for iPhones mean a physical sim and an e-sim.
The e-sim means an electronic sim which is already present in the hardware.
Hence you just have to set up the cellular plan for it on your iPhone without actually having to actually inject the physical sim.
In order to set an e-sim, make sure first of all that the particular carrier actually supports the e-sim feature. Then head on to Settings > Cellular > Add Cellular Plan.
Hence, follow the onscreen instructions to set it up.
You can modify the e-sim version of iPhone 11 Pro Max to physical dual sim by changing a few ID resistors and replacing the SIM reader, however that is advanced repair beyond DIY scope.
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 17
Duração total: 87
