Ir para o conteúdo principal
2nd-generation magnetic AC power adapter for MacBook products, first released in 2012. Not compatible with previous generation systems. Available in 45W, 60W, and 85W versions.
26 Perguntas Visualizar todos
Magsafe 2 85W charger will not charge 2015 MacBook Pro
I have an old 85W Magsafe 1 charger with a T-tip (yes, it’s an odd ball one) that I converted to a Magsafe 2 T-tip by resoldering a brand new Magsafe 2 T-tip cable. It charges all all of my laptops without issues:
  • 2013 13” MBP Pro
  • 2014 15.5” MBP Pro
  • 2015 13” MBP Air
They all show light up solid green when charged up or solid amber when charging.
Unfortunately, the charger won’t power up my 2015 13” MBP which has the battery disconnected. The amber light on the cable blinks and then turns off. My other magsafe 2 chargers will at least power it up with a solid amber light. As a test, I tried at least three different chargers and they were able to power it up without issue.
I highly doubt I botched my conversion. Are there other differences either in the MBP 2015 Pro circuitry or the Magsafe 1 circuitry that may cause it not to charge.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Ah, you really can’t use it as the power is lower. To add to it the MagSafe connector has a ID within it to ID the charger and the voltage to the system to prevent improper usage.
Teardown and exploration of Apple's Magsafe connector
Time to get the correct charger for your system. And please for your safety and your systems use a real Apple charger! The chargers you find on Amazon and eBay are knockoffs which will damage your system and have been known to set buildings ablaze!
Esta resposta foi útil?
Pontuação 1
I keep a couple of these Apple MagSafe to MagSafe 2 Converters around. They are cheap and work very well.
https://www.googleadservices.com/pagead/...
Pontuação 0
Adicionar a sua resposta
AppleGuyPie será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 437
