Ir para o conteúdo principal
Locate and remove a jammed coin which resulted from a toddler overenthusiastically shoving change into the toy.
2 Perguntas Visualizar todos
How can I fix it?
I found the panda version of it on the street. Its pressure plate is stuck and the panda as well.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
If this is a mechanized device and a coin is jammed, the mechanism is jammed. The may require disassembling the unit to reveal its internal mechanics to examine it up close. Whether gear or levers are used, sometimes its obvious where to reverse the mechanism to unstick the stuck coin. Good luck as this may result in damage as an inexpensive piggy bank. A rocket scientist isn’t needed as most parents have to deal with real world child raising issues more important than rocket science. Parents raise future rocket scientists.
Esta resposta foi útil?
Pontuação 1
2 comentários:
I just received the cat version of this but when i press the plate it only says “Hello” and doesnt look out nor steal the coin. How do i fix it. Its my first time using this? Should i return it?
por
Using a fresh battery? If it doesn't operate, return it for replacement or refund.
por
Adicionar a sua resposta
XxNatalia_UwUxX será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 29
Duração total: 729
