logic board for internal ssd not being recognized
So my mac does´t recognize any internal ssd, old or new, but works fine with external drive… would changing the logic board be a solution?
Done all the probable tests that can be done and it still won´t show the internal HD
Thanks in advance
Esta é uma boa pergunta?
6 comentários
What are the SSD's you've used Make and model
por Dan
@danj The original that comes with the mac and a crucial p1 nvme 500gb with adapter
por rfo223
@rfo223 - Need to know a bit more on the Apple drive is it a Toshiba or Samsung?
Using a M.2 SSD requires an adapter and they often fail. Apple added a bit of special sauce within their custom connector that messes up M.2 SSD's once you stress them. I personally don't recommend them.
Less focus on getting your Original Apple SSD going.
por Dan
@danj Thanks a lot Dan, it is a Samsung
por rfo223
@rfo223 - What is the model number?
Check yours against this The Ultimate Guide to Apple’s Proprietary SSDs Jump down to Generation 3 section
por Dan
Exibir mais 1 comentário
