Can I use it as a display only?
Is it possible to connect a mac mini to my iMac and use its display? How can i do that, what will i need and are there issues that i might face?
Update (07/31/2021)
Will i encounter issues like the following?
- The iMacs display will be at maximum brightness
- iMacs fans will run at full speed because of the heat
Esta é uma boa pergunta?
5 comentários
You can use the brightness keys on the Mac Mini's keyboard to adjust the brightness. I'm not sure why the iMac's fans are running at full speed.
por Andrew S
@andrewsawesome have u actually tried to make the brightness adjusting from the mini keyboard and it works?
por genik
@genik I don't have an iMac. You can also use the Display Preferences on the Mac Mini.
por Andrew S
@andrewsawesome on what Mac have u tried your suggestions?
por genik
I haven't tried my suggestions.
por Andrew S
