Ir para o conteúdo principal
The Apple Watch Series 1 is a revamp of the original Apple Watch, announced September 7, 2016. Most of the parts are the same as the Series 2
Touch screen not responding to touch.
I replaced my battery. It worked but the touch screen won’t respond to touches anymore. What part controls the touch responses? Trying to figure out what I need to replace now. Thank you!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
On an Apple Watch, the LCD and Digitizer are fused together. Make sure the LCD and Digitizer cables are firmly connected. It's also highly possible you may have torn the ribbon cable, in which case you need to replace the display(guide here). At this point, it might be worth getting a new Apple Watch.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Luigi Di Natale será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 16
Ao todo: 261
