Ir para o conteúdo principal
The April 2014 update of Apple's 13" MacBook Air features refreshed dual-core i5 and i7 processors, plus slightly increased battery performance.
313 Perguntas Visualizar todos
Why is my MacBook Air 2014 not powering up?
I decided to restore my MacBook Air 2014 few hours ago, after wiping the HDD through the Disk Utility, I tried to re-install the OS X and it started the update for a while and all of a sudden the screen just went black and it didn’t come back up again. I tried to press down the power button for it to power on but nothing seems to be working as the system refuses to power up at all since. Please has anyone ever encountered this issue before?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Hi press the pwr button and hold down the Option button
Esta resposta foi útil?
Pontuação 0
1 comentário:
Tried that just now and it still didn’t power up
por
Lets give this a try, follow this guide to disconnect the battery stopping at Step 3 Substituição da bateria do MacBook Air 13" do início de 2014
Now with nothing plugged in, press the power button for a good 15 sec to fully discharge the system. Now plug in the MagSafe charger (don’t connect the battery) your system should spontaneously restart, did it? The MagSafe charger LED should be Amber if not you’ll need to clean and inspect the MagSafe charger contacts.
Make sue your cable doesn’t look like these!
If they do you need a new charger!
Do the pins look OK
Make sure the plastic area is also clean like the bottom connector.
Here’s the proper charger for you system Apple 45W MagSafe 2 Power Adapter for MacBook Air Don’t go cheap! The knockoff chargers are no good!
Pontuação 0
Adicionar a sua resposta
Donald será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 41
