Ir para o conteúdo principal
Lançado em 4 de novembro de 2017. Modelo A1865, A1901. Disponível com GSM ou CDMA / 64 ou 256 GB / Prateado ou Cinza Espacial. (Pronunci-ase com X como número romano, isto é, iPhone X é o mesmo que “iPhone 10”.)
iPhone X Screen Burn
So today I repaired a customers IPhone X screen. The customer had a screen burn with the keyboard being the location of the burn. Due to this being an AMOLED screen I am familiar with this issue. However after putting on multiple different screens, the screen burn was still there. Any ideas?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
Are you copying the screen data to the new screen? If so I have seen this happen a few times where the burn gets transferred as well as the data. I don’t think there is much you can do except delete the data off the screen and lose true tone.
Esta resposta foi útil?
Pontuação 2
It could possibly be a problem with the screen’s connector on the logic board. Depending on the color and intensity of the burn in, a pin on the motherboard could possibly be burnt or have another problem with it. It could also possibly be a capacitor however I would expect it to be a pin on the connector. Hope this helps!
Pontuação 0
Adicionar a sua resposta
Neal Thomas será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 580
