Ir para o conteúdo principal
Lançado em 26 de outubro de 2018. Modelos A1984, A2105, A2106, A2108. Disponível como GSM ou CDMA / eSIM, nano-SIM ou SIM dual / 64, 128 ou 256 GB / Preto, Branco, Azul, Amarelo, Coral ou Vermelho. (Pronuncia-se "iPhone 10 R.")
My iPhone XR got water and here is the screen now, please, I NEED HELP
So, I washed my iphone. I've been doing this since corona started. From then before this, my iphone is fine. But now, the screen is like this. People said it is water damaged. I know I’m stupid because the iPhone shouldn't be washed. But the question is, how to fix this screen? pleaseeeeeee, I NEED HELPPPPPPPP :(((((
Esta é uma boa pergunta?
Pontuação 4
2 comentários
My phone is not still working please
por
My son dropped my phone in the toilet my whole screen went bkack what can I do to fix it
por
Adicionar um comentário
3 respostas
Solução escolhida
Hello! Welcome to iFixit! The iPhone XR is water resistant, and Apple actually says that you can wash the iPhone off in water if you spill something on it or it gets very dirty. However, water resistant phones are not entirely water proof, and water can still get inside of them if you wash them off in high pressure water. This usually happens if water gets blasted directly into the bottom charging port or speaker grills. Your iPhone should still be fine because it appears as if the water is only under the front glass of the screen, which is very common in cases like this. To try to salvage the iPhone without replacing any internal parts or opening it up, turn the iPhone completely off and opening up the SIM card slot and taking out the SIM card and tray. Place the iPhone in an open air environment where air can freely circulate on its own. Do not apply heat to the iPhone as this is often a last resort and could damage internal components. You can place the iPhone in front of a fan if you have one. Allow the iPhone to dry out for about one to two weeks. Again, the longer you wait the better chance you will have of your device still working. You could also try to use a vacuum cleaner and suck out some of the water from the iPhone. To do this, place your hand over the open SIM card slot and create a tight seal around it. Then, you can place a vacuum hose or attachment on the open side of your hand. You can also try to suck out water from the charging port and speakers using the same method. Repeat this as many times as you would like. Each day you leave the iPhone to dry out, you should notice some slight improvements with the splotches on the screen. You can briefly turn the iPhone on and then back off to check this. Do not try to use rice or silica packets to remove moisture from your iPhone. They are not as effective as letting it air dry. These are all things to try before opening up the iPhone to assess and diagnose the problem further. If these methods do not work after some time, then leave a comment down below and I can assist you further. Have a wonderful rest of your week and happy fixing!
Esta resposta foi útil?
Pontuação 4
12 comentários:
thank youu so muchh, i'll follow your guide!!
por
@myraa You are very welcome!
por
also, for future reference, don’t wash your phone like that. Use a wipe, not a straight liquid.@myraa
por
@Dylan Devries yupp, I'll remember that, thank youu!!
por
i was helping my mom cook and i go my phone wet it was on 1% and i put in in rice for 24 hours or more but it wont turn on can you please help me
por
Exibir mais 7 comentários
So you dropped your iPhone into the water. Unfortunately, it happens to the best of us. When I was working in an Apple Store, we would see people with the same problem every day, ranging from salt water to toilet water. It's never good, but it might not be too late to prevent water damage to your iPhone.
The very first thing to do is to gently remove your iPhone from the water and turn it off.
Now leave it off!
This is the most difficult thing I ask of you. Resist the temptation to check if your iPhone is still working and leave it turned off. The second you hit any of these buttons you might do more damage, so don't.
With that done, let's see what you need to do next.
What to do if you drop your iPhone in water
1. Turn it off immediately
2. Take your iPhone out of the case
3. Ease of liquid out of ports
4. Remove your SIM card
5. Wait for your iPhone to dry
Pontuação 3
7 comentários:
After that incident, unfortunately I immediately checked whether my iPhone was still working or not. My bad. I've turned it off, left it in front of the fan and I'll wait until tomorrow. Maybe tomorrow I'll check the progress. Ayway, thanksss for the answer, it really helped me.
por
what happened? does it work?
por
I spilt it in water and it’s hybanating I don’t why
por
My iphone keep turning on and off in a black screen after it was dropped inside water
por
Hi @michael87180, did you try any of the suggestions in the thread above?
por
Exibir mais 2 comentários
if the water is really in there and after drying doesn't come out you may need to replace the screen, because layer by layer disassembly of the screen is too complicated even for the experienced.
Pontuação 1
Adicionar a sua resposta
Myra será eternamente grato(a).
Visualizações:
Últimas 24 horas: 12
Últimos 7 dias: 65
Últimos 30 dias: 289
Ao todo: 50,365
