Ir para o conteúdo principal
Xbox One controller was introduced in 2016 with the launch of the Xbox One S and adds Bluetooth support for Windows 10/11. This controller fixes many of the design flaws found on the Model 1537/1697 controllers and is much more reliable. This controller has been replaced with the improved Model 1914 controller.
163 Perguntas Visualizar todos
RB doesn't work at all
Hi all!
I bought a used controller that looked unused cheap and I found out later that the right bumper doesn't work.
I'm new to controllers and this is what I've done:
  1. Updated firmware on Xbox accessories app
  2. No input from RB in testing software(Tried pressing hard and ALOT
  3. Opened up to see whether the bumper arm was broken but it's still pressing onto the switch
Would appreciate any advice as I'm planning to solder on a new switch from AliExpress.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
I’ve come across this with other devices that utilize essentially the same sort of module. They are a pain to take apart and re-assemble. However in each case what I found was barely dirty/dusty/oxidized/corroded internals.
My new nintendo 3ds power button was randomly turning on and or off. I disassembled it and used canned air to blow around the little button into the button module itself (not the external button). You might need some way to depress the button or shove it a little to the side, so the blast of air can fully enter the module. In another case I had canned air didn’t work but contact cleaner did.
But since you plan the nuclear option, full replace. Wouldn’t hurt to try air or contact cleaner first.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Leonard Wong será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 83
