iMac Internal display Black but External Display Working
I have an iMac End 2009 W80054XD5RU. Recently while upgrading the HDD I had to unplug the LG built in display and while doing so the Vsync cable snapped. I put a new cable but now the internal display is detected but I don't see any image (completely dark black / blank screen, with no image even when I checked through torch light). The external display is working fine and iMac runs perfectly.
I am wondering if I have the change the entire LCD panel or the inverter board? The Internal display connector (LVD) is slightly loose from the logic board but the pins are connected properly. I don’t see the 4th diagnostic LED turned on. How should I solve this issue to get back my internal display to work?
Also, the LCD temperature sensor in the logic board has been damaged, can that be a cause why the display is not turning on?
Update: I don’t know how and why, the internal display suddenly turned on but its flickering and white pixels are sparkling all over the screen noticeable under close inspection. What can be the issue? I have added the picture for reference. The screen sometimes goes black and comes up in a second or so.
Esta é uma boa pergunta?
Please add another picture of the LVDS cable from the other side so we can see the pins.
por Dan
@isadhu91 " is slightly loose from the logic board but the pins are connected properly." no reason for it to ever come loose. Take another close up clear picture and post with your question. From the one you have posted it looks like you have 1 or 2 pins that don't look to well connected. I would at least try a quick resolder of the connector.
por oldturkey03
@danj I have added the LVDS cable. cable feels a little fragile but the connector pins seems okay. not sure if this one I need to replace.
por Kaushik Sadhu
@oldturkey03 I have posted the picture for your reference, the connector came loose because the display snapped from the logic board while being connected via the LVDS cable. But the pins seems to be unharmed. only the outer ends (left and right) have come up a little bit.
por Kaushik Sadhu
It would be great if someone could help on the root cause, I am puzzled b/w LCD, Inverter, DisplayPort, LVDs. Thanks!
por Kaushik Sadhu
Exibir mais 2 comentários
